XS Power
im going to be running 3000 watts on fi btl 12" and i need to know if i need to upgrade alt its a 110 amp stock alt or if 2 d3400s will be good?
Edited by fi audio
Setup:
Headunit: 7" indash screen
Sub: fi bl 12
Amp: Audioque 1200D
Box Ported tuned to 34hz
Big 3 done in 1/0 gauge
DO big 3 wire up the 3400s and check drop when you rail it if it stays in 12s your fine for now, if not go with high output alternator if you can afford it.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1134 Guests (See full list)
