MAXSPL_153 Posted October 3, 2010 Report Share Posted October 3, 2010 ok so im starting the box dims. and tryin to sketch some stuff out and ive run into how much volume the sub takes up in the box . i looked online for the specs and not really gettin it .theres a whole bunch of abriviations ive never seen before , and if i think im looking at the right number it says that an soundstream xxx-18 only takes up .136 ft3 ... that dosent seem to sound right to me .. am i looking at the right thing on the spec sheet ? heres the link for the specs.. http://www.soundstream.com/AudioProducts/Subwoofers/xxx.htm i know ill probly get a bunch of hate mail on this question , but ive never really cared to build a box right to spec untill this build , so i gatta do it right . if it helps im doing the low tuned optimal enclosure . 6 ft3 with 2 6" x 22" ports .. probably aeros. Link to comment Share on other sites More sharing options...
moetpoppin Posted October 3, 2010 Report Share Posted October 3, 2010 i think thats it bro they dont usually take up huge amounts a lot of times if you forget to account for it in the design with one woofer, you wont hear a HUGE difference i know im about to get chewed out by some people for saying it doesnt make a difference, but read what I said one woofer, and wont be a huge difference it will, just like anything, effect it slightly however not significantly depending on the box and amount of drivers now if you forgot to account for that for 5 woofers, youd be missing a whole cube... how ever, again with 5 woofers, a cube wont make a HUGEEE difference as you should probably already have a big ass box think about it as a percentage. sound stream says 8 cubes max, 6 optimum, and 4 min 0.136 cubes in each of those would be 1.7% difference in 8 cubes 2.27% difference in 6 cubes 3.4% difference in 4 cubes so obviously the smaller box you got, the bigger difference you will notice but a 1.7% difference most likely will not be audible others feel free to chew me out if im wrong ty TY Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy Party and Bullshit - The Notorious B.I.G. Honest estimate on this truck when it's all done........... 172.3........... Ehh.. U are aware of what 172.3 is, right? yep..... Two Pyle 15"s Build log Link to comment Share on other sites More sharing options...
MAXSPL_153 Posted October 3, 2010 Author Report Share Posted October 3, 2010 hey thanks man , put it easy to understand .. i AM running more than 1 . im walling off my burban with 4 of um , but i plan to make a seperate box for each , then stack them in and frame it off to look like one big box . i fugured id have a little more sq doing it this way , and id have a better chance of not screwing up the dims of the box rather than wall it off as one big azz box. lol call crazy , but thanks for the advice man i appreciate it . only problem now is to determine how to make a 6 ft3 box with the sub and ports on the face , being deep enough for the 22" ports without going over 6 ft3 . Link to comment Share on other sites More sharing options...
