Hostility Posted October 4, 2010 Report Posted October 4, 2010 im about to add a 2nd run of + front to back, and also add my 2nd battery in the back. right now i have my 1 run, fused up front, and at the back battery, and then each amp is fused off the rear batt. now my question is, do i need to fuse again on the front and back on my 2nd + run, and then will i need to fuse between the 2 batteries in the back? (each batter is on either side of the truck, so say about 6-7 ft in between them? would i need one beside each battery? if so, that means i need 4 more fuse holders? im starting to run out places to put these things lol 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
David Posted October 4, 2010 Report Posted October 4, 2010 yes, yes, and yes. 18 inches from any battery in your vehicle
Hostility Posted October 5, 2010 Author Report Posted October 5, 2010 i figured, was just hoping i didnt have to buy more fuse holders lol 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
Hostility Posted October 5, 2010 Author Report Posted October 5, 2010 what size fuses should i use in between batteries? im running a sundown saz 2000, and a sax 125.2 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
