cheese20323 Posted October 7, 2010 Report Share Posted October 7, 2010 I would get A SAZ2000d and wire to .75 if possible still trying to figure out. 92 Accord Build Link to comment Share on other sites More sharing options...
dugee81 Posted October 7, 2010 Report Share Posted October 7, 2010 The thing is my 3 subs will only handle 600-700 rms each so a 3000 watt amp even if it is running around 2500 rms will still leave me in fear of popping them and i dont like always thinking they might blow and easing on the volume, i like to play full tilt at all times. just because it states to do 3000wrms @ 2 ohm, doesnt mean you have to set it that high. that and factor in that it will be @ 2.67, and you will have box rise more than likely. these are just suggestions. using a DMM, set the AC voltage to 73 volts (~2000 watts) as opposed to whatever the AC voltage would be for 3000. EDIT: or yeah, go with cheeses suggestion. well i would probably get a 1500D and wire it down, that would work great. 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
teamace24 Posted October 7, 2010 Author Report Share Posted October 7, 2010 What kind of electrical would i need to sustain that low a voltage, i really do not have a top of the line electrical i can barely sustain my audiopipe 1500 at reasonable voltage. 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
teamace24 Posted October 7, 2010 Author Report Share Posted October 7, 2010 Also how can i wire my 3 4 ohm dvc subs down to .75? 1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31 Link to comment Share on other sites More sharing options...
polkfan Posted October 9, 2010 Report Share Posted October 9, 2010 Alpine mrp-M2000? http://www.sonicelectronix.com/item_12019_Alpine+MRP-M2000.html Link to comment Share on other sites More sharing options...
