rsanchez Posted October 13, 2010 Report Posted October 13, 2010 need some help on building an enclosure, i want to buy 2 re xxx 12, but not sure of how big to build the enclosure. i found this member build on here and am going to do the same idea cutting up the back of my truck.(http://www.stevemeadedesigns.com/board/topic/72104-scary-truck-rebuild/). i used the torres box tuning calculator given on this sit. played around with it, and i dont know if 8 or 9 cuft would be to big or there is no such thing as too big? any ideas? i want to tune it around 35hz. amps probably the AQ2200D. not sure until i decide 100% if i will buy the subs.
Jbabycsx Posted October 13, 2010 Report Posted October 13, 2010 need some help on building an enclosure, i want to buy 2 re xxx 12, but not sure of how big to build the enclosure. i found this member build on here and am going to do the same idea cutting up the back of my truck.(http://www.stevemeadedesigns.com/board/topic/72104-scary-truck-rebuild/). i used the torres box tuning calculator given on this sit. played around with it, and i dont know if 8 or 9 cuft would be to big or there is no such thing as too big? any ideas? i want to tune it around 35hz. amps probably the AQ2200D. not sure until i decide 100% if i will buy the subs. What kind of vehicle? What are the deminsions of the space you have to use? 2000 GMC Sonoma AQ20 FTMFW! 4 DC XL 15's Cadence ZRS-C9 Infiniti Kappa 3.5's and 6x8's Bravox 6.5 components
rsanchez Posted October 13, 2010 Author Report Posted October 13, 2010 What kind of vehicle? What are the deminsions of the space you have to use? well i was thinking about 21"hx40"wx25"d and probably mdf 1 to 1.5 inches thick. i dont know if you saw the link i added its on a chevy truck similar to the one on the link.
bassl0va Posted October 14, 2010 Report Posted October 14, 2010 2 12"s, 8 cubes would be a bit too big, maybe 5ish My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
rsanchez Posted October 14, 2010 Author Report Posted October 14, 2010 2 12"s, 8 cubes would be a bit too big, maybe 5ish ok, since i have read that these subs need a lot of space to get their full potential that's why i thought going a bit big. Ok so in between 6 and 7 would be ok, 5 seems a bit too small?
