Need 18" sub info!
Reconstructing my new set up and having trouble on a sub. I'm looking for a sub that can pack one hell of a punch but not break the bank. I'm looking not to exceed the $600 mark. Somewhere around there. I want ALOT of handling power LOUD and DURABLE! the amount of trunk space i have is eehhh. Its an 83 Olds big body like the big cadillac square types. Any input?
1983 Olds Ninety Eight 2 Door Coupe
****CURRENTLY UNDER CONSTRUCTION****
DC xl
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
might try going with 2 smaller subs if you want to put alot of power in your setup, 2 sundown z 12s or 15s would work well. if your stuck on just getting one sub, then you could do a nightshade v2 18, but they wont be back in stock for a bit
  • Who's Online   1 Member, 0 Anonymous, 1008 Guests (See full list)
