MidnightBumpin Posted October 19, 2010 Report Posted October 19, 2010 So i plan on running 2 SA 15's or 2 15 AQ SDC 2.5's Both of those subs RMS at 600. Im looking for an amp that will feed each sub about 700 RMS. Im currently looking at an MB Quart DSC-1500.1D, Audiopipe ap15001d, Or a Soundstream STL1.1200D. I was wondering if anyone has had any personal experience with eather of these amps and which amp you would recommend. Personally im leaning to the MB quart or Soundtream more But hopefully you guys can have some helpful input.
AA98hoe Posted October 19, 2010 Report Posted October 19, 2010 so many better amps out there AQ,dd,rockford,ab,sd,hifonics, TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
MidnightBumpin Posted October 19, 2010 Author Report Posted October 19, 2010 Yeah but see i dont have alot to spend. Trust me i want a sundown 1500 sooooo bad those things are nice. But untill i get a better job ill have to dream a little smaller.
