Where would the IACV be on a 1995 chevy lumina(updates)
It's a 95 you said? You'll have to pull the code yourself, I don't think those can be scanned...
http://www.extreme-check-engine-light-codes.com/GM%20OBD1%20Decoder.htm
That should help ya.
Thanks for that I will have to try that! It seems simple and easy enough!
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
rebel lets see some more pics of your lumina
R.I.P!
(Nov-29-2009)
92 explorer
current build
I'd rather have something that evaporates/burns quickly in my intake/motor compared to water. Water in an engine is a VERY bad thing. My .02 :)
Water's ok as long as engine is running and it's a minute amount.
How do you think people clean the top end of their engines without disassembling them?
A can of Top Engine cleaner followed by some water.
Ever see a piston of a cylinder with a coolant leak?
Nice and shiny.
