yes sir, 2 runs from alt to front batt, 1 run from alt to rear batt (s)
I would remove the run from the alt to the back and the last battery you installed. Ground your amps to the batteries not the frame. Amps that size with a 220 alt, two batteries and big wires should not be pulling that much from your voltage.
2000 GMC Sonoma
AQ20 FTMFW!
4 DC XL 15's
Cadence ZRS-C9
Infiniti Kappa 3.5's and 6x8's
Bravox 6.5 components
it wasent in the first place, but i am planning on running my amp down under 1 ohm, next year, so i figured i might as well beef it up now, thats why i added the extra wire, and battery.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
well i just ordered up a XS power VCM to see if that can help my problem.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
sounds good man
but remember you said you didnt buy it to upgrade more things haha
TY
Moet poppin', hoe hoppin', aint no stoppin' B.I.G. poppa, I'm a bad boy
Party and Bullshit - The Notorious B.I.G.
Honest estimate on this truck when it's all done........... 172.3...........
Ehh.. U are aware of what 172.3 is, right?
yep.....:)
Two Pyle 15"s Build log
lol i know i know, but i figured this isnt to much of a loss, as it could be used for more applications. and was the cheapest solution other then selling a battery. But i could also sell the battery and still use the vcm, never know, depends on how it all plays out. but i am going against what i said a bit lol.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
Is it a possibility that the new battery you got isn't charged or is no good, therefore causes your alternator to work harder trying to charge it?
Teamflexissueslong.jpg1995 Sonoma with camper shellJVC KD-R900(12) Incriminator Audio Lethal Injection 15s
Crescendo BC5500 ( sent to me not 18v capable)(7) XS Power d1600(2) 350amp Mike Singer AltsStripper Pole FTW
Member Build Under ConstructionYoutube Videos
well thats what i was thinking at first, but i bought it off a good friend of mine, and he charged it before he gave it to me, and resting voltage after letting my truck sit for 3 days, was still good, the resting voltage actually went up .2 adding the new battery. Also driving conditions are fine, works great, only time it dips down a lot lower is when the bass hits.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
  • Who's Online   0 Members, 0 Anonymous, 2696 Guests (See full list)
