my orig plan was to run 5 SA8's, i already own 2, so i know how they preform. But im also wondering if i should do 2 sa 12's instead? they will be running off a saz2k, and im willing to run down to .5ohm daily or at 1 ohm. these will be in a s10 ext cab. running 4" aero ports. i know its hard to figure out what would be better, just need some more help deciding. I listen to mostly just music off the tunez section, low bangers.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
depends on what type of music you like. if you like a long range of types of genres...id say do the 2 sa12s with 2k on D2 coil. gonna give you some good bass and will fit in the ext cab. but running 5 sa8s on one amp in the same amount of room, you will ultimately have more cone area to move area. but who knows what it will sound like that much power to each woofer plus figuring out on what type of music you listen to. my vote is to go simple and do the 2 12s. going to sound better in my opinion.
im already running 2 sa8's now, and they sound good on all music. i listen to everything, but mostly bump loud to slowed stuff from decaf and bigpimpin91 in the tunes section.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
This one boils down to this question. Do you want to be different?
If so run 5.
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
id say the 5 sa8s but with 5 your not going to get .5 or 1...it will end up some funky number
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
i dont care about being different really, no one around me runs sundown. also the ohms will come out to be .66 ohms, will that matter at all on the amp?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
That amp should be fine with .66 ohms, provided your electrical is sufficient. I've seen people run them at .375
Edited by 01 S-10
TDH FTW !!!
yea im working on it right now, but should be good for .66 ohms.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
4 what?
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
  • Who's Online   0 Members, 0 Anonymous, 1707 Guests (See full list)
