higher voltage=lower gain
thats it
in theory, you gain a higher dynamic range (since there is more room for distortion-free voltage differences) and a reduction in noise (noise is amplified less because gain is lower)
but few sub amps have noise, and even with 2.2v you should have more then enough dynamic range for a subwoofer. Especially with orion, they dont like high input voltages anyway.
It literally has nothing to do with how hard the amp works or how loud it can get. So long as the amp can reach its peak output with the signal provided (which i guarantee that orion amp can) than you gain nothing from higher input voltages.
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
