Posted (edited)
you have to have 2 1ohm dvc subs to get a 1 ohm load or 2 4ohm dvc subs
EDIT: you can only get .5 or 2 ohms outta a single 1ohm dvc sub.
Edited by cubs_fan0718
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
you have to have 2 dvc 1ohm subs to get a 1 ohm load or 2 dvc 4ohm subs
ok i might get a recone cause im afraid my amp cant handle .5 ohms
Currently in a build
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
Pioneer AVH-P2300 (next purchase)
High output alt 150 amps
Posted (edited)
try the12volt.com sub wiring in diagrams to help... you have to have dual 2 ohm DVC
Edited by Winn
You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back.
JUST SAY ANTI-AUDIOPIPE
not only do you have to have a good amp but ur electrical needs to be top notch to be able to safely run @ .5ohms
06 Impala SS
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
yeah i might keep it at 1 ohm till i get a new alt and battery
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
But Upgraded batteries, alternator, and big 3 handle AQ2200 at 1 ohm?
and also upgrade ur wiring to 1/0
06 Impala SS
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Yes, im running my amp @ 1 ohm
06 Impala SS
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
i dont have the audio q yet i still have a hifonics brutus 2100 i think i will upgrade the electrical stuff first so when i do get the audio q it will be redy to run at .5 ohms
2 BTL 18s
1 AQ 2200
4 Kenetic hc 600s
