peacedisturbance Posted October 23, 2010 Report Share Posted October 23, 2010 how do i wire a 1 ohm dvc to 1 ohms i know how to wire it to .5 ohms but dont know how to make it 1 ohm Quote Currently in a build 2 BTL 18s 1 AQ 2200 4 Kenetic hc 600s Pioneer AVH-P2300 (next purchase) High output alt 150 amps Link to comment Share on other sites More sharing options...
cubs_fan0718 Posted October 23, 2010 Report Share Posted October 23, 2010 (edited) you have to have 2 1ohm dvc subs to get a 1 ohm load or 2 4ohm dvc subs EDIT: you can only get .5 or 2 ohms outta a single 1ohm dvc sub. Edited October 23, 2010 by cubs_fan0718 Quote 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017 Link to comment Share on other sites More sharing options...
peacedisturbance Posted October 23, 2010 Author Report Share Posted October 23, 2010 you have to have 2 dvc 1ohm subs to get a 1 ohm load or 2 dvc 4ohm subs ok i might get a recone cause im afraid my amp cant handle .5 ohms Quote Currently in a build 2 BTL 18s 1 AQ 2200 4 Kenetic hc 600s Pioneer AVH-P2300 (next purchase) High output alt 150 amps Link to comment Share on other sites More sharing options...
Winn Posted October 23, 2010 Report Share Posted October 23, 2010 (edited) try the12volt.com sub wiring in diagrams to help... you have to have dual 2 ohm DVC Edited October 23, 2010 by Winn Quote You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back. JUST SAY ANTI-AUDIOPIPE Link to comment Share on other sites More sharing options...
cubs_fan0718 Posted October 23, 2010 Report Share Posted October 23, 2010 ok i might get a recone cause im afraid my amp cant handle .5 ohms not only do you have to have a good amp but ur electrical needs to be top notch to be able to safely run @ .5ohms Quote 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017 Link to comment Share on other sites More sharing options...
peacedisturbance Posted October 23, 2010 Author Report Share Posted October 23, 2010 not only do you have to have a good amp but ur electrical needs to be top notch to be able to safely run @ .5ohms yeah i might keep it at 1 ohm till i get a new alt and battery Quote Currently in a build 2 BTL 18s 1 AQ 2200 4 Kenetic hc 600s Pioneer AVH-P2300 (next purchase) High output alt 150 amps Link to comment Share on other sites More sharing options...
Winn Posted October 23, 2010 Report Share Posted October 23, 2010 not only do you have to have a good amp but ur electrical needs to be top notch to be able to safely run @ .5ohms But Upgraded batteries, alternator, and big 3 handle AQ2200 at 1 ohm? Quote You know how you avoid that? Man the fuck up and bang her best friend sister mom cousin worst enemy and never look back. JUST SAY ANTI-AUDIOPIPE Link to comment Share on other sites More sharing options...
cubs_fan0718 Posted October 23, 2010 Report Share Posted October 23, 2010 yeah i might keep it at 1 ohm till i get a new alt and battery and also upgrade ur wiring to 1/0 Quote 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017 Link to comment Share on other sites More sharing options...
cubs_fan0718 Posted October 23, 2010 Report Share Posted October 23, 2010 But Upgraded batteries, alternator, and big 3 handle AQ2200 at 1 ohm? Yes, im running my amp @ 1 ohm Quote 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017 Link to comment Share on other sites More sharing options...
peacedisturbance Posted October 23, 2010 Author Report Share Posted October 23, 2010 But Upgraded batteries, alternator, and big 3 handle AQ2200 at 1 ohm? i dont have the audio q yet i still have a hifonics brutus 2100 i think i will upgrade the electrical stuff first so when i do get the audio q it will be redy to run at .5 ohms Quote Currently in a build 2 BTL 18s 1 AQ 2200 4 Kenetic hc 600s Pioneer AVH-P2300 (next purchase) High output alt 150 amps Link to comment Share on other sites More sharing options...
