dcofer Posted October 24, 2010 Report Posted October 24, 2010 I am going to be designing and building a box for my friend in the near future and wanted to get some advice before I did. The box isn't the hard part but its the install that im not sure about. I will be putting a 15" L5 in the back of a 2008 civic SI and I was planning on facing it forward and sealing it off from the trunk, so sub forward port forward. Is there anything specific I need to do to the trunk opening to secure the box? I am assuming I can build a frame and bolt it to the metal wall edges with some foam between to eliminate vibration, then just have the box screwed to the frame. Does this sound like a good approach? also I doubt the sub will be able to stand vertical (but it might, the trunk is 1.5 hours away so i cant measure) so also would it matter if I angled the sub up or down? The box will probably just be built to specs since space is an issue (though I hoping I have enough space to modify it hehe). I am not a metal worker and do not plan to do any modification to the car itself aside from drilling and bolting. All advice and tips are greatly appreciated.
jeyrapboy Posted October 24, 2010 Report Posted October 24, 2010 When i did my buddy car all i did was use L shaped brackets on the back of the box. Then made trim panels and spray foamed it to seal it off.
