while its playin have you tried wiggling the rca's around and see if the popping noise happens
no good sir i have not on amp or hu or both ?
Pioneer MVH-P8200 Hu
Dc Lvl 4XL 15"
AudioQue 2200 sold
Knu wire 1/0 ultra fleks & Krystal Kable Rca
Stock alt
Stock battery up front
Xs S3400 in back sold
your trunk lid is going to get molested like a drunk stripper at an orgy.
yeah try at both ends just lift it up make sure its connecting tightly Ive had rca's that were not tight around where they plug in it was with some monster rca's could be happening did they plugin tight also could be deffective rca's or possibly the amp?
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
yea they where nice and tight, has that happened before for Aq stright out of the box this thing has less than 24 hrs on it ???
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
I'm not aware of problems for aq it happens sometimes with amps you get problems with them even if they are brand new do you have a friend with a system with no problems that you could try your amp in? see if it is the amp or other equipment problem
big 3 1/0
eh kina not really lol
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
ill go mess with the rcas and set the gain with my dmm and let u know, can u help me out with low pass, boost & sub sonic ??
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
pictures? Im at a loss at the moment Im also wondering about your deck
big 3 1/0
pics of what mane anything specific, wtf is this shit im trying to dl decafs test tone and its pissing me off not working
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
where the wires run where they hook into the amp the deck grounds all of it and when you down load his zips just right click it to open it
big 3 1/0
subsonic should be at least 5 hz below tuning this is important cause you can damage or blow sub ive done it. set low pass between 60 to 80 whichever you prefer if you must use your bass knob like i do :) turn it all the way up and your gains all the way down and bass boost on amp down . get a song you know turn your head unit up 3/4 volume then turn gain up slowly till you see clip light blink. this way is if you dont use scope or dmm
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
