So i installed my system last night (lv 4 xl 15 and aq 2200) i have a few problems firstly the clip light on my knob starts to flicker with it hardly turned my little over 1/4 knob, im on stock batt and alt so im guessing that's from the voltage drops, secondly every once in a while it like burps and freaks out im not sure whats wrong with it.. it seems totally random when it does it but it sounds like shit when it happens its more like a nasty pop even when its turned down it does it sometimes, like earlier at the end of air forces that last shitty super low note it did it ugh nasty i hope nothings blown this shits too new, i got a few pics if anyone cares to see them :lol:
Edited by Bowser91
Pioneer MVH-P8200 Hu
Dc Lvl 4XL 15"
AudioQue 2200 sold
Knu wire 1/0 ultra fleks & Krystal Kable Rca
Stock alt
Stock battery up front
Xs S3400 in back sold
your trunk lid is going to get molested like a drunk stripper at an orgy.
what kind of rca's are you using also I assume you at least used a dmm to tune the amp also I'd suggest a seecond battery in the back even with the stock alt it will help for a short term for voltage drop
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
knu krystal kable rca's and didnt have my dmm out there when i installed im not beating the shit out of it or anything why would it be poping like that
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
The gain setting isn't a volume knob.
It is possible that sometimes you don't actually need to use gain, so at 0 or in some cases it needs to be maxed out.
It's all install dependent, if it flickers at 1/4 gain, then the gain is still too high as simple as that. ;)
the popping just sound like a something groundin out just tryin to get an idea if you have a loose rca or a wire grounding out
big 3 1/0
the amp is also a posible culprit need some others to chime in on ideas
big 3 1/0
coould someone point me in the direction for test tones so i can set it with a dmm, also what about lpf and subsonics and boost ?
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
decaf has some
big 3 1/0
hmm nothing should be grounding out the wires on the sub are zip tied to there own side of the basket im lost at this point :unsure:
Dc Lvl 4XL 15"
AudioQue 2200 sold
Stock alt
while its playin have you tried wiggling the rca's around and see if the popping noise happens
big 3 1/0
