Rebel4055's Lumina build log. It's going to be junked!
R.I.P!
(Nov-29-2009)
92 explorer
current build
dont worry i wish i could help more
and make sure you measure and remeasure your box dimentions haha first box ended up at 35" when it needed to be 33 because the stupid strut towers
R.I.P!
(Nov-29-2009)
92 explorer
current build
My cut sheet.
2- 33.5x16.5, 2- 16.5x14, 1-12.5x30.5, 1-12.5x33.5, 1-12x12.5, 1-24x12.5
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
hmm i'd watch out going higher then 16
these box measurements are
W 33
H 15.5
D 22.75
your doing 2 12s?
R.I.P!
(Nov-29-2009)
92 explorer
current build
The only problem I have now with this new HU is that I have to put the Loudness on high because if I don't I can max the amp gain and still won't be correct....
I put everything back to default and will think of something.
you want my box design it fits 2 12s
5.2 cubes tuned to 33
R.I.P!
(Nov-29-2009)
92 explorer
current build
