Wiring Question
I have a 2006 toyota 4runner, I am planning to put 3 amps, 2 JL 500/1's & a JL 450/4. Would you guys run two batteries, I already have a yellow top & I was thinking a Kinetic HC600 for my system. Is this a good idea ? & do you know if welding wire is a good chioce. I am built on a TIGHT BUDGET.
REF'Smr.wigglezdj - ROE- Traded, Hemisott - CA- Bought, BLD25 - CA- Sold, pik - CA- Sold, Priest - CA- Sold, FLOSSINON24S - CA-Sold, BJFISH11 - CA- Bought, SlainNothing - CA- Sold
If you go with a bigger batt like a 2400 along with your yellowtop up front, just do a good big 3 with 1/0 gauge to the rear & you'll be fine. Welding wire is cheap & flexible & thick, Go with KLM cable from knukonceptz.com. You cab get around 50feet for around 80bucks. also, if you're really on a budget, go with one of the batts in my sig from walmart. It's 70bucks, & puts out around the same AH rating as an HC2400.
May I ask why ur going with JL if on a budget? or two separate amps for the subs?
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
I had JL from past installs with no complaints, I will be running 2 RE se 12"s & 4 MB Quart pce216 with 1 MB Quart pce210.
  • Who's Online   0 Members, 0 Anonymous, 4342 Guests (See full list)
