I looked around a bit and was getting mixed searches and wanted to be sure I will be getting the correct one.
Now we wanted to replace the stock radio in my moms dodge dakota with a aftermarket one but the issue we are having is that the stock radio has these 2 round pieces, its hard to explain but I think this one would work but not 100% for sure.
http://www.amazon.com/Stereo-Install-Dakota-wiring-installation/dp/B000KL2VK6
In that picture you can see it has the 2 rounded areas like I need but still not for sure.
Going to take a picture and will update the post.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
it doesnt but i guess in these trucks they dont have an acc switch turn on so thats what the harness is for u dont really need it if u know how to wire ur own accessory turn on from like the fuse box etc. thats all it does
I guess the only way to find out if I need a special one is to remove the current one and take a look behind it.
But another issues comes up LOL! How do I removed this stock radio?
here is the wiring diagram just incase u need it
2006 Dodge Dakota Car Stereo Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located in the passenger kick panel.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Brown
Right Front Speaker Positive Wire (+): Gray
Right Front Speaker Negative Wire (-): Gray/Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Dark Green/Dark Blue
Left Rear Speaker Negative Wire (-): Dark Green/Orange
Right Rear Speaker Positive Wire (+): Gray/Dark Blue
Right Rear Speaker Negative Wire (-): Gray/Orange
and try to carefully pry with a flat head screw driver between the highlighted areas that whole cover should come off along with the AC vents start from the corners or edges
Edited by jl_audio
  • Who's Online   1 Member, 0 Anonymous, 781 Guests (See full list)
