.35 or .035 ohm?
i had each sub wired to .35 (2 subs wired to 1 amp) internally bridged down to 0.175 per amp
R.I.P!
(Nov-29-2009)
92 explorer
current build
You cant go wrong with any of those subs. I would run a DD 9518 as a daily sub though. The SMD's sound amazing. I heard 6 of them bumping in a Hummer this weekend and those subs hit every note thrown at them with authority. The DC level5's and the DD's sound very good too, but I think they are geared more towards SPL.
ok first answer these questions and i think we all might be able to help you out more:
1.What vehicle?
2.What is your electrical? can you feed that amp?
3.Whats your budget? (doesnt seem to be small)
4.What are your goals? SPL? Daily ground pounder?
5.Whats your experience level?
Johns.jpgSuburban Coming Soon
Hmm ok cool, thanks for the info. I have actually herd different about the subs. I have herd that the DD is better geared towards SPL. I guess its a shot in the dark now lol..
Edited by Spencerfitch88
1.What vehicle?
1. 2008 Vw rabbit Hatch back. Laying down the rear seats so i have plenty of room.
2. I have a deka intimidator under the hood. Going to go with an Optima Yellow top in the rear.
3. I have around $1,000 give or take for subs. (depends on the deal)
4. Looking for a Daily ground pounder. This is my daily driver
6. Last system was a solox 12 with a kicker kx2500.1. same car and everything. Sold it all for a motorcycle now i miss my audio lol.
i'd recommend a different back battery for you. also what music do you listen to? and do you like flat or peaky boxes?
Thats not an issue on the battery.. And I listen to all rap, box will be tuned to 30hz or so. Most likely will be a wall.
  • Who's Online   1 Member, 0 Anonymous, 1737 Guests (See full list)
