What type box should I use?
Ok, So I just got a new Powerbass XL 8" sub and was wondering what kind of box I should use. I'm pretty new to making boxes and stuff but I'm willing to build whatever type would be best, I want it to be more SQ and hit low than anything else. So does anybody has some suggestions??
You could just throw it in a sealed. Or you could have a ported designed for you, or get funky and do a bandpass if the sub is suited to it. Or, go crazy and do a tapped horn or something, but they need quite specific T&S specs.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
Here are the parameters.
VC Impedance: 4 ohm
Test Impedance: 3.98 ohm
Fs: 43 Hz
SD: 211.24 sqCM
Vas: 9.65 Ltr
Cms: 161.088 µM/N
Mms: 90.7 g
BL™: 12.876
Qms: 5.367
Qes: 0.663
Qts: 0.58
No: 0.128 %
Spl: 89 dB
Xmax: 6 mm
I'd like to do a tapped horn or t-line.
You can build either of those boxes for it, but it most likely isn't really suited. Since this is probably one of your first subs you should probably start with a ported box or so, no offense of course, it's just that T-lines and tapped horns have lots and lots of theory behind them, which is why I can't design you one, since I haven't researched them enough yet, nor have I built either of them.
Here are some websites if you are interested though:
http://www.danleysoundlabs.com/pdf/danley_tapped.pdf
http://www.cowanaudio.com/th.html
http://www.avsforum.com/avs-vb/showthread.php?t=1212465
http://www.quarter-wave.com/
  • Who's Online   0 Members, 0 Anonymous, 549 Guests (See full list)
