AQ SDC2.5 Boxes (Plans Included, please help!)
I know everyone's tired of these, but I've looked everywhere for more specs as to what these subs like. So I will make this quick and painless.
Ideal box for 2 12" or 2 15" subs? Probably going to tune to about 32-33Hz, daily use, hip hop mainly. Either way, going to use an AP1500.1D to power them @ 1 ohm load.
Also, will a center port work? Thanks.
POTATO!
I'm currently running 2 12" SDC's off a Sundown 1500. 4.25cubes net, 38Hz tuning and 16^2 port area. Sounds good on all types of music.
If you play mostly low stuff then tune to 35Hz. Unless you have an SUV 15's won't fit in the proper sized enclosure as they like BIG boxes.
I run SDC's in the same enslosures as the HDC's...
Since it's hard to read, I'll retype what I wrote (because my handwriting sucks)
2 x AQ SDC2.5 12" Subs, Audiopipe 1500.1D
Box: 16" H x 36" W x 19" D, Port 14" H x 3" W x 23" L
1" MDF, 4.68 ft^3 Gross Volume, 3.75 ft^3 Net Volume, tuned to 32Hz
Cut: 2x 36" x 14" Front/Back ; 2x 36" x 19" Top/Bottom ; 2x 19" x 16" Side ; 2 x 14" x 14" Port1 ; 2 x 3" x 14" Port2
Also a shot from the box designer: th_BoxAQSDC2512Calc.png
Think they'd like the 32Hz I came up with?
EDIT:Refigured the port to tune to 35Hz. Just imagine a couple inches trimmed off each side of the port wall, too lazy to edit and reupload it. But the way I have it set now is showing 35Hz. Is that a better option for these?
POTATO!
Bump for need of assistance, going to be working on this as soon as next week...
POTATO!
  • Who's Online   0 Members, 0 Anonymous, 3995 Guests (See full list)
