Ideal would be to upgrade your alt and add 1 battery. That would be the best situation. Would reduce most if not all of stress on your electrical system.If moneys tight you could just do the alt. and might be able to get away with just a good XS/Kinetik battery stock alt.
for 1500rms he will be absolutely fine with a battery. no need for an alternator.
As well as the big 3 :)
If you already said you did it, my bad.
I did plan on doing the big 3 for sure. But that is great news. I appreciate immensely the amount of replies I received so quickly. Thanks guys! I will look into a battery. What would be some batteries you guys recommend and where should I get them? Online or at a local audio shop. I appreciate it a lot guys!
a kinetik 1400 or 2000 should do you fine
2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log
http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
Thanks! Ill pick up the 2000 just to be safe! Cant hurt to have the extra power. Id assume to just run that to the back of the car if all possible so I have the shortest power wire to my amp?
1/0 Power Wire All Around + Big 3 - $140
Rockford Fosgate T2500-1BD - MSRP $1800
(4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200
XS D6500 $245.65
PIONEER AVH-P5200DVD 7" Head Unit = $430
Soundstream SC-6T Component 6.5" FRONT $60
Pioneer TS-A1673R 6.5" REAR $85
A Bangin system! = PRICELESS!
yes just like what everyone said, you should be fine just with a bigger batt or two and big 3. i had 4k on my stock civic alt with 3 oem batt with no problem.
REFF'S
My link
EBAY
get them from online, if you can try, get one from the for sale section on here.
I picked up the Kinetik HC2000 today - I was planning to install it today but I am not sure whether I replace my starting battery with this one or if I am suppose to run them together with 1/0 and put this Kinetik in the back of my car. What do you guys think I should do?
Thanks!
XS D6500 $245.65
Posted (edited)
**Double Post**
My Apologies
Edited by rickyfromthe407
XS D6500 $245.65
Thanks!
May wanna watch so you don't double post sometimes. Just saying.
I think the better thing to do would be do big three to your stock battery, let it run your car electronics, and run a wire back to the battery in the trunk, perhaps if they have a spare wheel well? I've just seen that way work better with most builds.
POTATO!
Thanks!
Yes I apologize for the double post - I guess I clicked a few too many times. I corrected it!
But ok I will do what you said. Ill need to buy some new terminals if I want to run a 1/0ga to this (hc2000) in the back. I guess that sounds better anyways to have two batteries over 1. I appreciate the replies guys! Will have this fully installed by xmas! Will be a good present to myself. :lol: :lol:
XS D6500 $245.65
  • Who's Online   0 Members, 0 Anonymous, 833 Guests (See full list)
