Guest MegaloManiac
oh ok, then you will be using ring terminals then i guess.
unless you plan to upgrade battery too?...
well the terminals arent just going to slide on like butter, cause then they would be kinda pointless... they have a screw to loosen it but you still gotta wiggle the hell out of it to get on nice then screw it.
maybe in the future, but not right now... is it ok to use a different bolt, that would be longer than the ones that are in there so that it actually goes into the battery?
as long as it conducts you're fine
ok, cuz thats what i did, when i needed a little extra space for running dual runs of wire to the amps... i didnt want to fuck with cutting it shorter with the die grinder, so i just piled on the washers... is there a way to see what amp draw each amp uses? and if i was gonna get a voltage guage/meter, how would i hook that up?
Guest MegaloManiac
the amp draw thing, only thing i have seen that can do that is a clamp meter.
the voltage meter, stinger has one to offer, its just like wiring an amp. 12v, ground, & turn-on lead
so i would just run another wire from the pos on the bat to the meter, and then back to the ground and wire the turn on to the ignition?
ignition, remote, accessory, whatever :)
yes
ok, so i could just run a wire from the remote on my hu... that would make things a little easier for me, and about how much they run?
i wouldnt really recomend runnin it off the hu cus it will most likely also carry the remote for the amp(s). i would go with connecting it to the ignition using a small fuse to be on the safer side. its better to spend on one extra small fuse and not have a fire ;)
and for the volt display, here ya go
http://www.hifisoundconnection.com/Shop/Co...sid/0/SFV/30046
there is also a red version which is a few bucks less
hope that helps :)
Edited by CynicLos
  • '02 Jetta
  • (1) Fi Btl 18 Inch Sub
  • Big box FTW!
  • Installed the HU.. finally...
  • Look for a H.O. Alt
    yea... it bangs.. but still need some few things
  • Who's Online   0 Members, 0 Anonymous, 4078 Guests (See full list)
