I just put in a brand new pioneer touchscreen to replace my aftermarket sony headunit in my 2004 ford ranger and it will not turn on. I checked all fuses, all connections, and the ground. It still isnt turning on. What else do i possibly need to do to get it going? The model of the touchscreen is the avh p3200 dvd.
Edited by JFox4
White 2004 Ford Ranger XL
4 Sundown Audio SA-8s sealed box :(
Rockford Fosgate T-1000
Pioneer 3200DVD
Optima YellowTop Battery
Rockford Fosgate 0 gauge
Damplifier Pro
138.5 DB @34 HZ
check your ground,also pull the plug out of the back of the stereo and make sure there is power all the way to the plug.see if that works.
HEAD UNIT JENSEN VM9312
4 12" KICKER COMPS
4 PUNCH 150 AMPS "0NE ON EACH SUB"
2 ALPINE 3522 ON MIDS AND HIGHS
MLA MOD
BIG 3
OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK
2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200"
DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
its fixed now, we checked the fuses in the fuse box and one was blown, replaced it, works now, thanks to a good friend :)
Pioneer 3200DVD
Damplifier Pro
138.5 DB @34 HZ
make sure its the right fuse powering it, most head units require a 20 amp fuse. some dick head put a 10 in mines and it keep blowing
