^^^^ Changing belts in those cars is a prick, you have to pull the upper motor mount. It's not so bad when you have a forklift to hold the motor up, but in your driveway, not so much fun.. Sanding pulleys is only a temp fix, a day, maybe 2 if your lucky, not really worth the time. If it's slipping, it will just re-glaze the pulley in short order..
Its a huge pain to change the belts, I will get you pics, my alt is a mechman 270 with the overdirve pulley, do your really have zero problems with the 3400's at your shop?
What size is your current belt? I can get belts in 1/8th in incraments...
I'm not sure, I know its 1 size smaller than stock.
@ OP i would look up the specs to your belt and give this a try...!
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
That's the thing, I don't know if I can go any smaller
Put a bigger pulley on the alt so u have more belt wrap. Not ideal but that should clear up the belt issue if the pulley is too small and causing the slip.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
