the split port should be have the width of the single port and you should keep that width the whole time so if the main one is 8 the port should spilt so its 4 inches back from the wall and the little "pyramid" isn't nessacary at all and can sometimes lower score i've seen ppl's test this thought
i always thought that putting in the 45s would help direct the air flow and keep the subs from loading eachother. i havent tested it so i wouldnt know for sure. im not challenging what you said. it sounds like youre more experienced with this design
hey no problem my man :drinks:. I just said what i've read from others testing it personally i haven't done it because the way i see it the air is going to move from High to low pressure since its following into the port its trying to get out into the cabin of "low pressure"
Johns.jpgSuburban Coming Soon
