Just wondering if I could run my amp a 2ohms on an Alpine Type R 4ohm version. Or am I better off with the 2ohm version?
Link to amp? If the sub is single 4 ohm, then it will only run on a 4 ohm load.
POTATO!
If its dual 4 ohm, you shouldnt have any problem running it at 2 ohms just hook + to +, - to - on the sub, then run + from sub to + on amp and - on sub to - on amp
Edited by Gatorcity
comic on tv: I got a concussion from playing t-ball when i was younger, we dont really have time to go into that!
15 seconds pass
my girl: no one pitches to you in t-ball, do they???
http://www.vminnovations.com/product_4486/Audiopipe_AP1800D_1800W_Mono_Power_Amplifier.html
750 Watt x 1 RMS @ 4 Ohms
1100 Watt x 1 RMS @ 2 Ohm
1800 Watt x 1 RMS @ 1 Ohm
Check out my first ever aftermarket purchase!
Should be ok, but I would be careful with setting gains, the type r's are only rated 500 watts rms I believe
15 seconds pass
Ahh dang I forgot to say Im going to be running two Type R's. So I'd say if I ran it at 2ohms, they should be getting just around the right RMS.
Edited by ChrisGLE
You can wire both subs together then hook them up to the amp to get a 1 ohm load
15 seconds pass
Alright I think I might eventually try that, but i'll probably run them a 2ohm for a while.
If youre running both at the same time, 2 dual 4 ohm subs cant be wired to 2 ohms, its either 1 ohm or 4 ohm
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results
Check out this link
15 seconds pass
