2 18" DC lvl 5's 6KW of Sundown in a VW Lupo!
Thanks for all the good comments... I'm in Birmingham, UK.
Can't wait to get her on full power, should get my other two amps 20th Feb, really looking forward to the score increase... if its doing 150@ 29hz on a quarter power god help my little car lol
  • 1 month later...
Long time since ive updated so here goes
Got the other two 1500D's back in feb. Really impressed in the increase in output, its unreal. It actually hurts now :D. Missus was with me so tested a hair trick out with the door fully open and it pulled it off efforlessly, she wouldn't let me record it though :( ill post one up soon.
Had to stack the two new amps unfortunately but still looks good. Not sure whether the amps will live in this place one I do the amp rack trim but doing the job atm.
Also got a package from DVB... my imprint unit.
Here are the results pd format
Without blockers 35hz tuning
20hz - 143.2
25hz - 150.1
33hz - 153.9
40hz - 153.2
Peak@32hz - 154.9
Average 151.1
With Blockers 25hz tuning
20hz - 147.4
25hz - 151.7
33hz - 154.7
40hz - 153.5
Peak@31hz - 155.2
Average 152.5dB
Was 2 batteries down when I had this tested and the amps are strapped until I get my RCA's and then they will run 1 per coil, should make them more efficient.
I've gone for black perforated leather vinyl.... should look really classy and subtle.
Rocking the DC logo in the compulsory location lol.
Picked up some aluminium bar from a local metal shop so I can make some bus bars for the batteries as I've been struggling to connect my 0 gauge terminals to them as the post isn't long enough.... this is my solution.
The bar is 30mmx12mm... I plan to tap the holes for m8 bolts so hooking up multiple runs of zero will be a doddle.
Got a couple of deliveries.... some heat shrink, contact adhesive and thinners, sanding disks and some spade terminals.
Contact adhesive was bought from as trim and is absolutely amazing, never used an adhesive so good... and only a tiny bit is needed.
Speaker cable and 0awg, filler and fibreglass
15m blue stinger hpm 0awg
15m clear stinger hpm 0awg
75m yellow stinger speaker cable 12awg
Pretty impressed with the 0awg, more flexible than my knu fleks... the clear seems slightly more flexible than the blue, seems more rubbery.
Got my new runs of cable in today front to back.
Bought a big drill bit for my 0 gauge.
20mm holes cut
Negative runs.
Nicely terminated and heat shrunk.
Positive runs.
Cable tied
Spl taped.
Dynomatted around the holes so I don't get any unwanted engine noise.
Battery connected, negatives aren't connected until I finish the bus bars... also you may notice one of the cables are not fused, until I get my fuses.
Amp cables will be swapped out, then my other two batteries will go in.
First bit of bass damage.... so glad its the damaged door.
getting ready to start finishing off the wall... deadline is the 27th march for the fast show..... gonna be a tight one.
Started by pulling the dcs out.... on my own lol. Wasn't too hard tbh.
Then took the baffle off.
I've sanded everything smooth in the ports, bits of fibreglass and slightly overlapping mdf.... so airflow should be better trough the port.
Lots of dust!
Also got my standard wheels back from the powdercoaters with a fresh refurb, painted pearly purple. Tyres will be going on this week some time between doing the wall.
Decided the ports are going black too, might do them purple in the future if I like the theme.
Did few bits ready for the door builds today before work.
Knocked up a ghetto router jig Out of some birch and plexy for small cutouts. Really pleased with it, I have so much control whilst doing a circle it brilliant.
The mutt inspecting also.
Got half of one of the new door cards built today.
Did a few kurf cuts as my door isn't straight.
Used some plastic to recess the speakers. Tip nicked from mazdawg.
Painted Matt black.
I connected one of the speakers up to my jbl amp and they sound amazing, the mids off that one speaker was brilliant! All 4 are going to be brutal.
Got the door cards finished for the new speakers, really happy with the outcome. Ill let the pics do the talking.
Second door cut
Glassed
Filled
4 runs of 12 gauge, should be using 8 runs but depends on whether I go active or not.
Trimmed
Bad pic as it was dark.
I'll be using them at coaxials for now until after the fast show as I've got so much to do.
Trim pannel been made
From panel more or less done :D
Trim panel trimmed in perforated leather.
Hoovered out the masses of mdf dust from inside the box.
Subs in panel on
Better pic of the door pods
Oh yea I picked up my new toy
200.4 in the roof
Pic is really bad BTW lol.
Few pics from a show
Love the way the sundown sticker is in this one :D
Here's a pic of one of the hair tricks.
Still loads more to finish off but its slowly getting there.
Ben
