its cool. just dont rush it. make sure you understand everything before you build it. keep asking questions if you need to.
Thanks. That calculator says it needs to be like 4" longer. In your personal preference what do you think it should be tuned to?
wait. Is that one whole box, or 2 seperate boxes put together? If it's one, then you need to split the port down the center. You cant just have 2 holes, and a big long chamber like that picture shows. You need to either make it one full hole, or put a divider down the center. Here's an example of a single chamber.
get the idea? I think these types are confusing as hell. Id just do 1 4" aero instead of that slot.
2006 Nissan Z Track.
My Feedback Thread
cool idea with that center port
Thanks man, might as well use all the space i can right?
yea pretty much the bigger the better but not to big haha... what calculator are you using? try torres calculator.
I think you're almost better off just doing a sealed box. If I'm doing my calculations right, you only have 3.4 cubes sealed with that center area anyways. Might as well do aero ports as stated before and have them come out of the box.
POTATO!
there are two separate chambers. they are split i just didnt show enough detail and i guess it confused you guys, but i catch what you are saying. thanks man
2004 Ford Ranger Regular Cab
Sony DSX S-100
Alpine Type - R Door Speakers
Alpine Type - R 10 (In a Bazooka Tube)
Alpine PDX 1000.1
MTX Thunder 400.4
5 Farad Cap
High Performance Battery Under the Hood
- Brandon
