If they're on stock headunit, or aftermarket with no amplifier, then it's not putting out enough power. Get a good aftermarket H/U and/or amp, make sure the x-over is set to take out the low frequencies i.e. 80Hz or so. You can put a $1k set of speakers in a door but if you send it a $5 signal, it's gonna tell you to f*** off big time.
POTATO!
How is turning your sub control down on your headunit affecting your door speakers?
I'm thinking his H/U may be linked to the sub output. Mine is too for some weird ass reason...only has front/rear outs with the rear acting as sub...which is why I need a new h/u
POTATO!
Best to run your highs off the front output exclusively then.
Been doing that. Tried it with rear/subs sharing, but the sub controlled the rear output too. I'm hoping for a new h/u from Alpine for xmas so I don't have to worry.
POTATO!
  • Who's Online   1 Member, 0 Anonymous, 844 Guests (See full list)
