VW Golf II , A Swedish Beast
Thought i would post my project here.
Hello, My name is Magnus Svensson , 22 years old from sweden.
Rundown of the equipment this year;
Alpine 9887R
2 µ-Dimension Pro X 500.24 powering 4 µ-Dimension El Coax 6,5"
2 µ-Dimension dB 5000.1 strapped at 0,46 each amp powering 3 RE MT 15 Q0,7
7 Tudor Maxxima batteries
Oh well pics is the law on here i have seen so lets get some up
So i won swedish finals and became swedish Champion in bassrace 149.9 and Extreme OS 3+
And our method of deathmatch , db jams vol. 13 the music tracks are the only tunes we can use in bassrace so those we have to use, but i won!
Right as we speak im in the middle of a rebuild and are gonna put in 1 more MT 15" before WF :)
gotta be smooth! :D
gettin somewhere now.....
fixed my charging problem i have had this season , and got an adjustable voltage regulator
This was at the start , after 30 mins of idling the voltage was stable at 15.18 , so im really happy of the day
how about a new pic from this evening's little work :)
starting to get somewhere now
Only did up those 4 , its friday and i wanted for once , a friday evening for myself to relax and rest on , but hey , its saturday tomorrow, and that means noone at work and i can work! :D
Predrilled
Lots of polyurethan glue
allot of screws
the angle iron is only to hold it in place to see how i should do that piece
Been starting on the back a little, allot of space left :)
now i just wondering what if i should anodize or just sand down my bussbars to look like brushed stainless look... hm...
The only picture i took today, oh well , lots more happend anyway :)
Started a amp rack today , didnt wanna go all threaded thru all , so its welded and bolted so in case something happens, i can fairly easy lift them out
Abit more metal and some more welding and bolting, then i can brake it apart, and get it ready to paint it :)
mounted my bars yesterday
today was a real set back day , nothing fit , so after alot of head scratching and some re-building i know evrything will fit!
so i took my 3 batteries from the front and put them back
just need 1 more now
its tight, but it will fit
Starting to get somewhere with the box now , allot of fiberglass over evrything then we can start the sanding :)
finally had some time over to get back and started to mock up the new floor :)
started some fiberglass today
Just done with the first, time to bring in some heat
After some heat
After lots more fiberglass i was happy and called it done
How the floor became , it think its ok
After some people that was visiting me and whatching the build i started to work again
Used some spray adhesive,looks like airbubbles and ****,but its good :D
Thanks guys! :)
yeterday's work
today i did the roof
so i can start on doing the baffle now when i get some material
Got a little nice package today
Was my three amps and one thats not working , so i snagged it for mockup (will try to get it fixed)
After some time it looked a little something like this
Missing 1 battery here in the back, oh well, have to get something in the front too so
I really like my bars Dreddan drilled and threaded for me :)
Just threw in a ctek charger to charge overnight
After some wiring today it starts to get somewhere, now i just need a heck load of wire from the front to the bars
Soon, and dont worry, the black nuts will be removed ;) it was just to see how much i have to space it out
Hmmm......
What i did today
55% tint , cops already hate this VW :P
right side and bottom left, then repaint and then lots of windowglue and i hope it wont be leaking! beacuse how it was mounted before, it was leacking like ****!
Have forgotten to update here, so let the pics rain
Tinted the rear window
Started on the baffle
Cut them down to size
Jasperjigg is great!
Whoopa!
Dryfit
Dont worry, i didnt have any hex bolts , but they will come
Today Dreddan was here so he was kind enuff to do the messy part , sanding baffles
After he left i started to mix some resin and got to work
sanded it smooth and did another layer
and done for the night
Tomorrow i will put these in before work, and after work i will start the fiberglassing from baffle to the box :) should be solid
Those where screwed in last week
Todays work was wire up the front again...with new batteries
A linedriver will do wonderful things i hope
Then i started to with testing the portwall
glued, screwed and glassed in to place
abit of papper and siccors and tape and then transferd to mdf
jasperjigg is great! :)
other side done :)
A big thanks to Dreddan for rounding the port :)
Abit dusty, it isnt enuff to blow with airgun on it :( maybe i have to wash it :angel:
oh well, only 1 bad pic, but atleast its a picture
Resined the front....now i can sand it down and put filler over the screws and then thats ready for paint, hope to have the roof done soon , so i can shoot paint over those two areas at the same time
Some pics of the slow start of my new doors...
and i threw some black paint on the wall
and today i started on the roof building
have only started on the second layer... and its still not welded in to the roof...
continued today
so now its just to get it up to the roof, put a jack or two and push it upwards and then start weld the **** out of this so i an do the pieces from roof to windshield
Putting some pressure so i knew when i welded it , it would be at the top.... damn that got strong! i can lift the car like that now :D
Tried jumping up and down on the roof, but got tired of it, since it wont budge , and then theres still some pieces before wood and foam and a thin sheet of metal to close it up
Nice edge so i can get a new window and glue it down :)
And there i am today,
Merry Christmas evryone!
Awesome build dude. Got to love the Mk2. I got one myself. A 91 16V.
What alternator are you using. It looks to be a stock one. If its a upgrade for stock mount and location would you happen to have a link? Why not go with a ABF set up?
If it's worth building, it's worth over building.
