firefighter271 Posted December 29, 2010 Report Posted December 29, 2010 i have a 240 amp alternator and there is a threaded hole on the rear of my alternator should i connect a ground wire to it i was told that it was a grounding point. if so where should i ground it to
finkster Posted December 29, 2010 Report Posted December 29, 2010 Alt ground to battery ground DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
firefighter271 Posted December 29, 2010 Author Report Posted December 29, 2010 so i should put a bolt in there and run it to my battery
dsktim Posted December 29, 2010 Report Posted December 29, 2010 What type of vehical? what engine? what alt case do you have? Only DC Dealer In Alaska
firefighter271 Posted December 29, 2010 Author Report Posted December 29, 2010 2007 ford Explorer 4.6 v8 6G
dsktim Posted December 29, 2010 Report Posted December 29, 2010 sorry i dont know about fords im sure someone has used that alt before and can help Only DC Dealer In Alaska
finkster Posted December 29, 2010 Report Posted December 29, 2010 If it is to the case then it is the ground. Unless you are referring to the output stud. Yes, run it to the negative battery post. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
firefighter271 Posted December 31, 2010 Author Report Posted December 31, 2010 yes its on the case thanks for the help
Holden Posted December 31, 2010 Report Posted December 31, 2010 I just picked up a new alt. also congrats Chevy Avalanche Z66-BigBlue EditionPioneer AVHX2700BSCheap dont know brand(Front)2 Cadence 6.5"CVL midbass (Rear)2 78 series Autocraft Gold BatteriesStinger Battery Iso.New Mechman 270 amp alternatorLanzar OPTI4000DJbl 75.2DC SoundLab Level 5 18Lots of 1/0 and 4 gauge wiresFew 250/150 amp fusesOriental Blue House of Kolors Candy Paint18" ION alloy 179/Goodyear Wrangler Duratrac 275/70R18
