was wondering if there was any sheet metal workers here or anyone that uses air sheers regularly
i'm looking to see if this base model is up to cutting the metal of the rear deck near trunk
R.I.P!
(Nov-29-2009)
92 explorer
current build
thanks i'll send him a pm
R.I.P!
(Nov-29-2009)
92 explorer
current build
They work pretty good on flat surfaces. Cant say I have tried one in a car before. If you have to cut thru double thick material it will be a bitch. Because of the length of the tool getting in tight corners wont be easy either. Sometimes they dont like going over pressed/stamped areas. An air saw with a good metal blade would work well. A plasma cutter would make quick work of it. Might not be that much to rent one.
i was going to pm you just went out to garage to see how thick 17 gauge was with the caliper haha
as for the plasma i want to go with the least amount of sparks as we'll be doing this in the car
as for the sheers - i've used my hand snips to cut the rear deck before it worked but took lots out of you to do it so i'd imagine the sheers would make miens meat out of it haha
i just want the cleanest finish out of this when done
i'll look for some pics of what i need to cut
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
i only need to cut an inch and a half off each side and then straight back and across (taking rear deck out completely)
DSC01001.jpg?t=1293659918
DSC00904.jpg?t=1293660202
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
17 gauge is pretty thick. They should cut the metal in a rear deck pretty easily. Its more of a can you fit the tool in the places you need it to go to do the work. Maybe drill in the middle and work towards the sides. The problem with the big humps is that the shears have a sweet spot/angle that they like to be in to cut right. To high or to low and they just dont cut. Or maybe I just had an old dull ass shear lol.
Edited by -Hobby-
for the humps i have my bull nose snips and other tin snips (im a fireproofer by trade and have alot of tin snips
hmm buddy has a sawzal i think i could borrow
i thought of that earlier but figured snips would work
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
turbo shear
I use one of these all the time to cut furnace openings. Just put it on the front of a cordless drill. Whats nice is you can angle the drill and rotate it from side to side. Im mostly cutting 22g with these. The metal in those decks cant be much thicker than that.
