I'm going to be ordering a 15" BTL N2 within the next week or so and I'm trying to figure out which way is the better way to go with a box. I was looking at some prefab but none really caught my eye.
It's going in a 04 Tahoe, Not trying to use the whole trunk.
Possibly 40Wx18Hx22D as the Dimensions.
Anyone give me some ideas? Thanks
EDIT: Going to be running 2000-2200wrms.
Edited by Big_Mike
Is this for daily or comp? Need more info.
This will be for daily
What kind of music do you listen to? Are you willing to sacrifice output linearity for low end extension? Need to list some goals to get an idea on what you want to get out of your sub.
Well I listen to mostly decaf ^_^ and some regular music too. I want it to sound good on music but also put a decent score in spl lanes even though I won't be competing in contests.
Something like that?
Need a LOT more port area per cubic foot. You should be aiming at 12-16 sq in per cube.
Also make sure you take into account how many "common walls" your port will have i.e. walls shared by the exterior of the enclosure & the port. If you are doing one at the bottom of the box facing back, one common port wall. Not a whole big problem, but it helps.
If I were you, I'd go with something like a 12w x 8h port or something along those lines. Just make sure there's enough clearance between the port wall & the sub.
POTATO!
