If that box has 3/4" wood thickness, then it´s around 46 hz without including the sub displacement, so yes, it´s between 46 and 48 hz depending on the displacements you have inside the box.
whats the best way 2change the tune of the port---make it longer r what// and whats a good tune 2go with-like 30/32hz does that sound right/// and i can take the port out of the box just 14bolts in it// any help with this// thanks
Edited by just1moreamp
For daily i would tune around 35 hz, also, the FS of that sub is 35 hz if i remember correctly so i wouldn´t tune below that, port tuning changes when you add or reduce the port lenght, but also, when you get bigger or shrink the internal space of the box. Said that, modding your current box would save you some money!!
so how long do i need the port 2b to get 35hz and if i keep it 6'x6'then how long would that make the port thanks again for your help any help would be nice i would like 2get this done 2day i have the port out now so if someone can tell me how long the port needs 2b i can get this done asap---and thanks again
Remember that adding lenght to the port would also shrink the internal space of the box, what sub or subs are you using on that box? would need around 20" long to get a 35 hz tuning!
I'm pretty sure your port would need to be around 17+in long in order to achieve 35Hz
2 HDC3 18's
AQ2200D
i have the boston-g5/12' svc-in the box the man that done the box works at a shop that sells boston subs and this is what he built me and told me thats the box thay shoud be in-- but it sounds like shit on anything i play. this was a gift from me for a good friends sun on his-b-day- and i would like it 2sound good but ant shure what 2do to the box 2get it right..i have a boston gt28 runing the subs at2o at the amp and the hiend has a boston amp runing all boston 6.5comps in all 4doors the mid/top sound dam good bass like shit/// if any one can help me out with this it would be great--and again thanks 2all who have replyed 2this.
