ugh so I got everything home... went to hook everything up... the box is 45x26x22 ... supposedly tuned to 32hz... however... I got everything hooked up and my amp like... insta-kicks into protect mode when I turn up the stereo... please anything tell me why this is happening...
maybe the sub is setup for an ohm load that ur amp cant handle.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
Probably wired down too low. Also set your amp correctly. Don't crank the gain and everything to max. And no bass boost.
What amp you got.
I have everything turned all the way down... also... I have a Hifonics BRZ1700.1D
What amp you got.
Set Phase to 0, Set bass EQ 0 set subsonic 2hz below your boxes tuning, set the low pass to around 8O.
And I see the "level" on the amp is backwards. You may have accidentally maxed the gain.
Rest In Peace mother.
January 22, 1955 - February 14, 2013
http://www.stevemeadedesigns.com/board/user/35351-megrch/
What amp you got.
alright i am going to check the wiring and then check all settings on the amp... updates to come... fawk!
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
