dangerick18 Posted January 4, 2011 Report Posted January 4, 2011 Hi I have a 2001 Chrysler 300m and I have a few questions: 1) I want to run my own wire into the front door's cause my stock system is 2-ohm and @ the stock gauge it would only support 30w cleanly @ 4ohms. I already took off everything that I need to in order to take off the dash, because as far as I understand that's the only way to get to the front door jams. It's really been delaying the progress and I wanna do the front doors all in one block of time now that I have almost everything else disassembled. Has anyone had experience with this car and have any sort of tips? 2) Also I have a question about the rear deck.. I'm going to be mounting two 6x9's on top of the rear deck on 3/4" MDF and bolt them down... And I'm curious whether I should be closing off the holes on the bottom of the rear deck in the following picture: 3) Do you guys recommend any good sites with information on a stock alarm system? Thanks for your help.
bumonskateboard6 Posted January 4, 2011 Report Posted January 4, 2011 Never worked on a 300m before but here's the best info I can find for question 3. Hope this helps! 3) http://www.the12volt.com/installbay/alarmdetail/594.html Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
dangerick18 Posted January 4, 2011 Author Report Posted January 4, 2011 Never worked on a 300m before but here's the best info I can find for question 3. Hope this helps! 3) http://www.the12volt.com/installbay/alarmdetail/594.html Nice good link!
dangerick18 Posted January 5, 2011 Author Report Posted January 5, 2011 OK I have an update today... I found a way to run the front speaker wires through a doorjam. I also removed the piece of crap factory amp which also happened to be bolted kinda loosely anyways so I bet it rattled. Anyways I never realized what a pain in the ass it is to be tall and have big hands, even in a long car. I'm still tryin to get your opinions on if I should cover up the rear deck. I imagine it would sound better with them covered?
TheycallmeJT Posted January 5, 2011 Report Posted January 5, 2011 i had an 03 special edition 300m..i completely sealed off the rear deck with one of the systems i had in it..no problems what so ever by doin that bro
dangerick18 Posted January 5, 2011 Author Report Posted January 5, 2011 i had an 03 special edition 300m..i completely sealed off the rear deck with one of the systems i had in it..no problems what so ever by doin that bro Sweet man! I'm gonna PM you aight?
