Distance from port to inside wall
So right now im designing my new box, want to build new box. My dilemma is, im using 2 6" aero ports. My box is 24" tall, my port length is 17", but with both flares attached the total length of it is 18". That only leaves 5.25" from the wall to the start of the flare. is this ok? I know your suppose to leave 6" from the wall using a 6" port. But the port doesn't tech. start until inside the flare a bit, if that makes sense.
how i got that is. 24" tall, minus .75" for the bottom of box, then 18" port.
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
3 Sundown Audio SA-12's
Alpine H/U
RF Power Comp set 6.5"
RF 3 sixty line driver
5.25 cubes @ 31hz
that i didnt want to do. I also didnt want to make the box any bigger either. I just wasent sure if it was going to cause a problem or not :S
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
What tuning does that length give you?
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Just do it..it might not be a prob. and if there is port noise just add that last .75
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
I want the ports to be flush, so just adding .75 isnt easy. The tuning will give me 34.5hz
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
here is my box plan just in case anyone wanted to know
3 sa 12's
ports in box
height - 24
width - 45
depth - 13
port
2 x 6", 17" long
5.49 ft3
34.57hz
56.52 in2 port
or
12.5"port for 37.93hz, 5.66cubes
99 s10 4.3L
Big 3
220amp alt
Odyssey 1500
Odyssey 2150
Northstar NSB 75
Sundown Audio 3500D
Sundown Audio 125.2
Alpine H/U
5.25 cubes @ 31hz
If the ports arent glued together, assuming they came in 2-3 pieces, couldnt you just cut .75"-1" off then glue them together? Will raise the tuning frequency some but I doubt it would be noticeable
Edited by Gatorcity
comic on tv: I got a concussion from playing t-ball when i was younger, we dont really have time to go into that!
15 seconds pass
my girl: no one pitches to you in t-ball, do they???
You shouldnt have a big problem with it, but if you do have any port noise you can just shave off that extra .75 inch. with that little port area and the sa 12s you will still be able to get the lows and youll most likely only raise .5 to 1hz
  • Who's Online   0 Members, 0 Anonymous, 2166 Guests (See full list)
