car amplifier class d monoblock
my cuestion is, i have a car amplifier class d monoblock but if its a 1 channel why does it have 2 positives and 2 negatives ?? how do i have to hook them up to the speakers ??
That's just to help make wiring easier, even though it made you confused. The terminals are bridged internally so you could wire the sub to the amp using any of the + & - terminals
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
what about if i use both + and - to the same woofer ??
If the woofer is a dual voice coil sub, then hook one coil + and -, and the other coil to the + and -, or if it is a single voice coil sub, then hook the + into a +, and the - into a -. the other two outputs on the amp will remain unused. BUT when doing this, make sure you understand the impedance of the way you are wiring it, so as to not damage the amp.
2009 Cobalt LT
Pioneer Headunit
2x Pioneer 6 1/2 (stock amp)
2x Pioneer 1" tweeters (stock amp)
2x Pioneer 6x9 (stock amp
4x Pioneer 6 1/2
Pioneer GM-6400F
Soundstream DTR 1700 R.I.P
2x Champion series PRO 12" subs
0 AWG Big 3, Stinger SP1700 battery
To come:
New or repaired DTR!!
  • Who's Online   0 Members, 0 Anonymous, 4731 Guests (See full list)
