I think I read somewhere that sundown amps don't like stinger rcas for strapping. Any truth to this?
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
From Jacobs Amplifier FAQ
1) My amps work fine un-strapped but go into protection when strapped and/or my amps are stuck in protection. - 3/8/07
I have had three customers with this complaint. All three of them replaced their RCA cables to remedy the problem. Some model Stinger and Memphis RCA cables will NOT work with the SAZ-1500D, *especially* for the jumper RCA from master to slave based on the feedback I have received. Be advised... this should be the FIRST thing you check if your strapped pair is going into protection. It will usually be the slave going into protection if this is the case... but not always. "
the cheap ones work but the expert dont last i tried the cheaper the RCA the better
VEHICLE:1993 Ford F-150
ELECTRICAL:1-350Amp 1-200Amp Idle Excessive Amperage Alts.
BATT'S:13 Stinger SPV70's
HEAD UNIT:Pioneer N1
MIDBASS:2 10" 2 8" Sundown prosound protos
SUBS:3 NSv.2 18s in a series tuned 6th order
SUB AMPS:3 Sundown SAZ-4500D
MIDBASS/TWEETER AMP:Sundown SAX-200.4 Simon Eichenberger is the King
http://darvex.com/store/pc/viewPrd.asp?idproduct=541&idcategory=118
Thats the one im using right now. It works fine at low volume but when i attempt to crank it. It goes into protect. I have a 15' RCA i can use just to see if it makes a difference. Does the length of the strapping RCA matter? It'll be temporary if anything.
The change in RCAs fixed the problem. Didnt wanna leave the thread hanging with no answer
i used to run some stinger 4ch rcas, they where blue with the aluminum foil stuff on the inside and they were crap, the ends pulled off, where the rcas interconnect in that lil boot thing came loose
i still run the same kind of stinger rca to my sub amp but will replace it with my knu rcas, i replaced my stingers with some kicker 4ch rcas and i love em
on the knu rcas can u use the wire down the middle as a remote wire or would it work better if i grounded it? i was gunna leave it alone cause i have no feedback so far with my setup now
anyways glad u fixed ur problem :)
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
  • Who's Online   0 Members, 0 Anonymous, 1579 Guests (See full list)
