Possible ohm loads with 8, 10, and 12 dvc 4ohm subs
Just for reference what ohm load can you wire 8, 10, and 12 dual 4s into?
2009 Buick Lucerne CXL, Sundown SAZ-3000d,Sundown SAX 100.4,2 Shuriken SK-BT80 (80ah batts),Mechman Custom Alt (specs to be determined),Hybrid Audio Technologies Imagine I61-2,T3 Audio t2000 (2 12s) , JVC KWHDR720 (doubledin headunit w/iPhone adapter) , SecondSkin Damplifier Pro/ Speaker Tweakers......Build in progress but I have all equipment and Enclosure is going to be around 5 net @ 35hz
Bump someone should make a diagram like the jl audio but from 1-12 instead of 1-6
Is it even possible to get a 0.5 ohm load with this many woofers?
Double post on accident
8: 0.25 ohms, 1 ohm, 4 ohms, 16 ohms, 64 ohms. And maybe a couple of other crazy ones.
The other 2 are a pain in the rear.
12 can give you 6 ohms, 0.66 ohms, 0.167 ohms, 1.5 ohms.
10 can give you 0.8 ohms and 5 ohms.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 1168 Guests (See full list)
