Superjay Posted January 14, 2011 Report Share Posted January 14, 2011 of a star. about 10 million degrees kelvin ? kelvin is not a degree.. a kelvin is a unit itself mistaken...it's a scale just like Fahrenheit or Celsius... The kelvin is a unit of measurement for temperature. It is one of the seven base units in the International System of Units (SI) and is assigned the unit symbol K. The Kelvin scale is an absolute, thermodynamic temperature scale using as its null point absolute zero, the temperature at which all thermal motion ceases in the classical description of thermodynamics. The reference point that defines the Kelvin scale is the triple point of water at 273.16K (0.01 degrees Celsius). The kelvin is defined as 1/273.16 of the difference between these two reference points. The Kelvin scale is named after the Belfast-born engineer and physicist William Thomson, 1st Baron Kelvin (1824–1907), who wrote of the need for an "absolute thermometric scale". Unlike the degree Fahrenheit and degree Celsius, the kelvin is not referred to or typeset as a degree. The kelvin is the primary unit of measurement in the physical sciences, but is often used in conjunction with the degree Celsius, which has the same magnitude. 0kelvin is −273.15 degrees Celsius. Quote Principal JTech Consulting - Leader in 12-Volt Training and Product PlanningIt's not about how much power you have, but how well you use it Link to comment Share on other sites More sharing options...
fritosaregood Posted January 14, 2011 Report Share Posted January 14, 2011 of a star. about 10 million degrees kelvin ? kelvin is not a degree.. a kelvin is a unit itself mistaken...it's a scale just like Fahrenheit or Celsius... The kelvin is a unit of measurement for temperature. It is one of the seven base units in the International System of Units (SI) and is assigned the unit symbol K. The Kelvin scale is an absolute, thermodynamic temperature scale using as its null point absolute zero, the temperature at which all thermal motion ceases in the classical description of thermodynamics. The reference point that defines the Kelvin scale is the triple point of water at 273.16K (0.01 degrees Celsius). The kelvin is defined as 1/273.16 of the difference between these two reference points. The Kelvin scale is named after the Belfast-born engineer and physicist William Thomson, 1st Baron Kelvin (1824–1907), who wrote of the need for an "absolute thermometric scale". Unlike the degree Fahrenheit and degree Celsius, the kelvin is not referred to or typeset as a degree. The kelvin is the primary unit of measurement in the physical sciences, but is often used in conjunction with the degree Celsius, which has the same magnitude. 0kelvin is −273.15 degrees Celsius. i cant see where i was mistaken Quote seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970 Link to comment Share on other sites More sharing options...
mporettim Posted January 14, 2011 Report Share Posted January 14, 2011 of a star. about 10 million degrees kelvin ? kelvin is not a degree.. a kelvin is a unit itself mistaken...it's a scale just like Fahrenheit or Celsius... The kelvin is a unit of measurement for temperature. It is one of the seven base units in the International System of Units (SI) and is assigned the unit symbol K. The Kelvin scale is an absolute, thermodynamic temperature scale using as its null point absolute zero, the temperature at which all thermal motion ceases in the classical description of thermodynamics. The reference point that defines the Kelvin scale is the triple point of water at 273.16K (0.01 degrees Celsius). The kelvin is defined as 1/273.16 of the difference between these two reference points. The Kelvin scale is named after the Belfast-born engineer and physicist William Thomson, 1st Baron Kelvin (1824–1907), who wrote of the need for an "absolute thermometric scale". Unlike the degree Fahrenheit and degree Celsius, the kelvin is not referred to or typeset as a degree. The kelvin is the primary unit of measurement in the physical sciences, but is often used in conjunction with the degree Celsius, which has the same magnitude. 0kelvin is −273.15 degrees Celsius. i cant see where i was mistaken you weren't Quote Link to comment Share on other sites More sharing options...
