ive heard that if your hu has a crossover and your amp does too,to just use one or the other or they can cause sound issues.
what about bass boost?my hu has bb one and two level,plus subwoofer output level,and the amp has bass boost,ok to turn em up as long as subs are happy?
well my h/u has a pretty good EQ, but i can turn bassboost from -6/0/6 i useally keep my round 2, but be aware it causes clipping if you go to far with it
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
dont sum of the pro's use the bass boost on there decks? my hu has adjustable hz setting adjustable eq and 0-5 bass boost my EQ is set at 100 hz +1 80hz cross over -3 and ano boost. but i was told if u are carefull u can bump up the bb a lil bit just for a lil higher numbers
Team DBs (Driven By sound)
You probably scoped yours,if you do not have access to a scope do NOT use bassboost!
hehe i did :), but your right, dont mess with it unless you have a scope, i tripple checked my amp after i set my eq settings, i dont go above 2 tho cuz after that its clip city
