If think i got what i have to do here is a digram of what i am planing to do.
I'm doing something wrong ?
BTW the battery is xs power 5100 and not kinetik
Edited by As-21
Hertz HSK 165XL
Celestra FA475xDC Audio 3.5KDC Audio level 5 12 inchXS Power 6500 on the front.XS Power 3100 on the back.Knukonceptz 0 gauge an 10 gauge OFC wire.
Looks good except I would fuse at the amps as well.
1991 Lincoln Town Car Signature Series
DC Power 270 Amp Alt
Big 3
Kicker/KnuKonceptz 0 Gauge Power wire
XS Power D6500
XS Power D3100
Pioneer Headunit
JBL Mids and Highs
Rockford Fosgate 400.4
3 Sundown Audio SA-10's wired @ .67 ohms
American Bass 150.1
You mean to fuse the cable that comes from the battery before the distribution block ?
the distrubtion block fuses the 4 gauge cable to the amp with this
did you ment this ?
Hertz HSK 165XL
I mean fuse the 4 gauge cables going to the amp.
Big 3
XS Power D6500
XS Power D3100
Pioneer Headunit
JBL Mids and Highs
American Bass 150.1
with an anl fuse and fuse block
Ok thanks for your answer that how i planing to do it.
I bought this from knu:
ATC 30 Amp Fuse - 5 Pack 1 this for a friend.
Karma SS 8 Gauge Speaker Wire 10ft this for wiring the sub.
KonFused Negative Battery Terminal 1
KonFused Positive Battery Terminal 1
Kolossus Fleks Kable 1/0 JET Black Power/Ground Wire 33ft this for big 3 and run it to to trunk to the amps.
Gold Plated 1/0 Ring Terminal - Black 10ft for the 0 gauge wire "-"
Snap Bushing/ Grommet 1/0 5 for the runing up to the trunk.
Gold Plated 4 Gauge Spade Terminal - Black 6 for the amps 4 gauge wires.
Gold Plated 4 Gauge Spade Terminal - Red 6 for the amps 4 gauge wires.
KonFUSED High Current In-Line Fuse Holder (300A) 2 one for the big 3 and 1 for the trunk 300A
KonFUSED 3 Way Distribution System (100A,100A,100A) 1 from 0 gauge to 4 gauge with 100A each.
what do you think about that ?
Couple things they didn't have a Gold Plated 1/0 Ring Terminal on red where can i get 1 that fit knu wires ?
and how can i fit the knu Battery Terminals with XS power 5100 ?
Edited by As-21
Hertz HSK 165XL
i would ground the alt 2 the car and if u can run a other ground from the battery 2 the back and use a distribution block on the grounds and do a distribution block off the power for ur amps with it OWN fuse holder and fuse that it needs
hope that helps
Edited by splzx3
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Got question how can i put the knu battery terminals to the XS power battery is there a kinda adapter for that ?
Edited by As-21
Hertz HSK 165XL
ya there is, kinetic sells adapters, im sure a kinetic battery post adapter would fit
on your xs battery since there the same size ring terminals i think, search ebay :drinks:. also
you still need remote wire you didnt have it on your list. for that just run some thin wire
I got already a remote wire installed I'm upgrading the 4 gauge to 0 gauge the rest is already installed
Hertz HSK 165XL
