I keep hearing this noise going into my sub even with the music off and head unit turned all the way down. I tried turning everything down on the amp and it was lower but I could still hear it. Then the more I turned the gain up the louder it got. It was loud until the point where my car was flexing. I got the same thing with two different amps so I dont think that is the problem. I unplugged one of the RCAs and it was a little quieter but it could still be heard. Could it be a bad set of RCAs or maybe the RCA output from the head unit?
1998 Toyota Camry XLE V6Goldwood GW-S650/4 6.5sEA 200a alt2009 Lancer GTSStock jtte2o.gif
Try taking a wire from your right channel rca ( dont have to be right) and but it on the connector and put the new wire on the chassie of the cd player! Bad grounded RCA`s suck!
Try it out, had the same problem in the car that a bud of mine own! Did that and it cleared it tight up!
Hertz - Pioneer - Zealum
The RCAs that I have now are a cheap Power Acoustiks pair thats I've had for a few years. I'll prolly end up ordering some new ones anyway but I'll check to make sure thats the problem.
Happened to me when I first installed my subs. Went through everything but the RCAs, and it ended up being them, switched it out for some new RF ones and it went away.
2009 spring fling-iasca-rookie 1-Champion. 139.4db.
"I don't do enough, I just fool around
Ya'll can go to hell, how does that sound"~ Tech N9NE
4 15" Memphis. and 1 Big ass box. <-Sold to fund more power.
Kicker l5s
so many people dont strip the paint from the metal
also is the sound like a popping or a low hum?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
