Bogs Barrios Posted March 1, 2013 Report Share Posted March 1, 2013 Just bought 2 Polk Audio DXi104 10" on sale at BBY. Please recommend an enclosure design for this. Planning on a slot ported enclosure. not sure if I should go for common chamber or separate, looking for suggestions too Thanks guys for your help Link to comment Share on other sites More sharing options...
Joe X Posted March 1, 2013 Report Share Posted March 1, 2013 Ok post amp and vehicle models and maximum dimensions for the box Link to comment Share on other sites More sharing options...
Bogs Barrios Posted March 2, 2013 Author Report Share Posted March 2, 2013 for now JBL gto1004... thats what i have right now, planning to upgrade to a mono amp in the future... will install in an oldsmobile alero.... as for the dimensions maybe 30" for the length hopefully i can still have some trunk space Link to comment Share on other sites More sharing options...
stroupe79 Posted March 2, 2013 Report Share Posted March 2, 2013 JoeX will hook you up, but he is going to need your height, width and depth to do it.... http://www.stevemead...cherokee-build/ 2005 Jeep Grand Cherokee Alpine CDE-hd148bt Alpine PKG-RSE2 PRV Audio (4) 6MB200 front/rear doors PRV Audio (4) TW350Ti dash/rear doors Kicker KX350.4 Obsidian Audio (1) 18 D4 v2 revamp (2) Stereo Integrity HT 18d2DC Audio 1.2k5.25ft^3 tuned @34hz revamp Infinite Baffle Cpillar AudioTechnix 60mil deadenerKnuKonceptz & SkyHigh wire (complete setup) Link to comment Share on other sites More sharing options...
Joe X Posted March 2, 2013 Report Share Posted March 2, 2013 Ok so here is a suggestion: Enclosure Specifications:Fb = 34 HzVb = 2.5 ft^3External Height = 14 inExternal Width = 31.75 inExternal Depth = 16 inPort Width = 2 1/2 inCut Sheet List:* All Dimensions in Inches.* Wood Thickness is 3/4 for all Parts.External Enclosure Parts:Front & Back = 31 3/4 x 14Left & Right Sides = 14 1/2 x 12 1/2Top & Bottom = 31 3/4 x 14 1/2Shared Port Internal Assembly Parts:2 x Front to Back = 13 1/4 x 12 1/22 x Extension = 6 3/8 x 12 1/2 Assembly guide (generic dimensions): Important notes:- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.- All trunk boxes built outside the car need to fit in their way in not just have the right dimensions.- The port needs 2 1/2" of free airspace in front of it for proper operation.- Setting your amp subsonic filter to 28Hz is suggested. Link to comment Share on other sites More sharing options...
