Pioneer DEH 80 PRS?
Has anybody here had a chance to try to mount the PRS in a Buick LeSabre before? (Mine is a 97 Buick LeSabre with 6 speaker system) On both Sonic and Crutch field it says it doesn't fit my car. So for the hell of it I called crutch field and asked why. They told me the the PRS is longer than most decks and it won't fit. I thought single din was single din? I have an idea how to possibly make it fit? What if I cut the plastic of my dash to make the opening a little wider. Then I would put like 1/4" spacers behind the mounting holes of my dash kit. I would find some longer screws. My deck would then, just sit 1/4" farther out than normal. What do you guys think?
97 Buick LeSabre with stock 140 amp alternator
XS Power D3400 (under the hood) using pdb distro blocks
Big 3 done with 2/0 ga welding cable
Alpine CDE-HD149BT head unit
CT Sounds Meso 6.5" components
CT Sounds 60.4
CT Sounds 1400.1
Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs)
Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders)
Connection BT2 & BT4 550 (Audison) RCA's
Bunch of Mojo Mat
Side by side to an older pioneer deck looked like the same size to me.
measure height, depth, and width you can fit then call pioneer tech and get the measurements for the 80prs
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
It fits in any single din opening height and width wise. It may be slightly deeper because of the heatsink on the back of the unit.
Even if this is the case, you should be able to modify your radio pocket slightly in the back, most cars have room to expand.
  • Who's Online   1 Member, 0 Anonymous, 1668 Guests (See full list)
