Foamyy Thee Squirrell Posted April 23, 2014 Report Share Posted April 23, 2014 Can you explain to me 4th order and 6th order walls? Also whatever else there may be. Maybe some pictures or video links if you got them would be nice too. Still learning here. Someone suggested I do a 6th order wall and I am like what... Link to comment Share on other sites More sharing options...
Popwarhomie Posted April 23, 2014 Report Share Posted April 23, 2014 You try google? 2010 Focus coupe- 8 12" wall. 157.5@46hz 2016 Focus ST - SQ build. Link to comment Share on other sites More sharing options...
mrd6 Posted April 23, 2014 Report Share Posted April 23, 2014 I don't have time to write a whole explanation right now but my build log has some good examples of ported, 6ths and 4ths. Feel free to ask me questions in that thread if you have any. My Build Log: http://www.stevemead...-sundown-power/ Team NorthWestSPL Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 23, 2014 Report Share Posted April 23, 2014 i got you bruh..... gimmie a bit. and these are going to be VERY general examples. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 23, 2014 Report Share Posted April 23, 2014 6th... The red section is your "1st Ported" box [or chamber], which would generally be low tuned. The orange section is the "2nd Ported" box [or chamber] which is generally tuned high. The small rear portion (red) with low tuning helps retain cone control and front portion (orange) is more of the output section. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
Foamyy Thee Squirrell Posted April 23, 2014 Author Report Share Posted April 23, 2014 You try google? Yes. I just thought a car audio form was good place to learn about car audio. But I'll go back to google and keep trying to figure this stuff out. Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 23, 2014 Report Share Posted April 23, 2014 4th... The red section [ first chamber ] is a sealed section, while the second chamber is a moderately high tuned ported section [ orange ]. Same sort of mechanic going on with the rear and front chamber. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
Foamyy Thee Squirrell Posted April 23, 2014 Author Report Share Posted April 23, 2014 4th... The red section [ first chamber ] is a sealed section, while the second chamber is a moderately high tuned ported section [ orange ]. Same sort of mechanic going on with the rear and front chamber. So these are generally large builds? Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 23, 2014 Report Share Posted April 23, 2014 Here is a 4th order. See how where the subs are mounted the chambers are sealed, and then there is the middle chamber (front or 2nd chamber) which is ported. 6th order. see how the rear chamber (which holds the subwoofer) is vented or ported into the front chamber, then the front chamber has another bigger port exiting the 6th order. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted April 23, 2014 Report Share Posted April 23, 2014 4th... The red section [ first chamber ] is a sealed section, while the second chamber is a moderately high tuned ported section [ orange ]. Same sort of mechanic going on with the rear and front chamber. So these are generally large builds? yes, due to the fact you are basically putting the sub in a sealed and ported box... so almost 1.5times the volume of a normal box. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
