I might have been useful to know that the amp was cutting out on you previously.
Still could have been a ground issue though.
Yeah. Sorry about that. But this was way different. The amp wouldn't power on. Nor would it get up to 12+ volts with the new ground. I now know it's a grounding issue. Will be grounding to the frame now.
Vehicle: 2013 Ford F-150 STX SuperCab 5.0L V8 4x4
BIG 3: Knukonceptz Kolossus Fleks 0 Gauge OFC Power Amp Kit
Headunit: Stock (Leaving factory look)
Speakers: Stock
Subwoofer: Incriminator Audio Lethal Injection 10" D2 wired down to 1 ohm
Enclosure: ~1.5 cubic feet tuned to ~34 Hz (Port Area ~24 inches)
Amplifier(s): Sundown Audio SAE1000.1D
Amp Power Kit: Knukonceptz Complete 4 Gauge OFC Amplifier Installation Kit
You definintly can run a test wire to the battery to see if the amp is working.
Already did. I got 12.6V on the amp power and ground connections. Whereas before I would only get ~3V. Also did a small jumper from the power wire to the REM. Amp powered up and not in protect!!! I'm quite happy now.
Speakers: Stock
Update: Ran new ground to frame. Floorboard already had a hole in it from factory. Just had to use a punch to make a hole through the carpet. Now amp and LC2i does not cut out. Also, I made my own power and ground distribution bar. Wiring is better now as well. Thanks for all your recommendations!
Speakers: Stock
